Exporting Parametric Data
Posted 2011年3月17日 GMT+1 01:37Results & VisualizationVersion 4.0a0 Replies
Here's a slightly silly question that's nevertheless driving me crazy.
I am running a parametric sweep over about 100 parameter values and need to export everything to a text file (and eventually read into MATLAB). Under "Results", I go to "Report", add "Data" and find that I can only manually select a single parameter value to export at time. Obviously, I can't do this 100 times.
I found that if you play around with the solver, there are various places you can insert a parametric sweep. If I add "Parametric" under my "Stationary Solver", and run the sweep there, a complete list (not the pull down menu) after solving that allows me to export everything to a single file! This is great, except that at this level, only a single sweep is allowed (I plan on sweeping over multiple variables). I can't make any sense of this.
I do not have LiveLink.
Any help will be greatly appreciated!
-John
-John
Last Post 2011年3月17日 GMT+1 01:37
Hello John Ho
