Acoustic radiation from vibrating ring
Posted 2011年3月17日 GMT+1 16:14Acoustics & Vibrations3 Replies
Hello!
Please, help me with the following problem:
I study acoustic radiation from flexurally-vibrating ring in air using frequency response analysis and acoustic-structure interaction. In-plane vibrations of the ring are excited by the load distributed along one of its generating lines. Frequency of excitation is 35.8 kHz. Diameter of the ring is 25 mm, thickness is 1 mm. Eigenmode corresponding to these parameters has 12 nodal points and corresponding wavelength is rather small. I tried to create 3D model of the problem, but small wavelength demanded very large number of finite elements and performance of my computer (CPU 2.4 GHz, RAM 2.0 Gb) was insufficient to obtain good resolution of acoustic field pattern. Is it possible to use axially symmetric model for my problem? I have idea how to do it, but I need your advices on practical implementation of this idea. For example, I can perform frequency response analysis without account for air load and determine distribution of radial displacements along the perimeter of the ring. This distribution can be represented as a sum of harmonic functions of angular coordinate with different pitch (azimuthal wavenumber) using Fourier series. Then each harmonic term of Fourier series can be used as input exciting structural load for acoustic-structure interaction analysis. General solution can be obtained as a sum of solutions corresponding to input loads with different azimuthal wavenumbers using superposition principle.
Thank you in advance.
Best regards. Dmitry.
Last Post 2011年3月18日 GMT+1 07:26
