Heat exchanger, failed to evaluate variable
Posted 2011年3月21日 GMT+1 15:09 Fluid & Heat, Heat Transfer & Phase Change 2 Replies
I'm trying to model two counterflowing fluids (water and steam), which exchange heat through a copper surface. I'm using General Heat Transfer and Incompressible Navier-Stokes modules.
I've set up inlets and outlets in the N-S module and constant temperatures and convective fluxes in the heat transfer module. I've been messing with many settings and I may be close to solution, but now I'm getting the error:
Failed to evaluate variable U_ns
Geometry 1
Dimension 2
Domains{2}
I can't figure out what that variable is and how I could fix it. In Physics->Equation systems->Subdomain Settings I found a list of variables that has U_chns, but not U_ns. Even if it was there I wouldn't know what to do. Any ideas? I've attached the file (from COMSOL 3.4).
Geometry 1
Dimension 2
Domains{2}
2 Replies Last Post 2011年3月22日 GMT+1 14:49
