Grid settings in V4.0
Hi James,
I used to work on V3.5a but due to some reason, i need to switch to V.4.0. could you please tell me where i will find Grid settings in V.40?
Thanks.
Rony
4 Replies Last Post 2012年3月9日 GMT+1 21:35
Ruud Borger COMSOL Employee
Posted: 1 decade ago 2011年4月2日 GMT+2 13:30
Hi Rashedul,
You can find it under Definitions => View 1=> Axis.
Note that by right-clicking Definitions, you can add a new View, for which you can use different settings. In the graphics window, you can then switch between views (and grid settings accordingly) quickly.
Ruud Borger
COMSOL BV
Hi Rashedul, You can find it under Definitions => View 1=> Axis. Note that by right-clicking Definitions, you can add a new View, for which you can use different settings. In the graphics window, you can then switch between views (and grid settings accordingly) quickly. Best regards, Ruud Borger COMSOL BV
Posted: 1 decade ago 2011年4月2日 GMT+2 16:33
And in the postprocessing plot nodes you can select to use automatic or one of the predefined views in the top, or further down on the postprocessing section too (this applies to V4)
Hi And in the postprocessing plot nodes you can select to use automatic or one of the predefined views in the top, or further down on the postprocessing section too (this applies to V4) -- Good luck Ivar
Posted: 1 decade ago 2012年2月8日 GMT+1 19:27
Do this applies to V4.2? When I right click view1 I am unable to add an axis node. How can I add the axis node in V4.2 in order to modify the grid line spacing?
Hi, Do this applies to V4.2? When I right click view1 I am unable to add an axis node. How can I add the axis node in V4.2 in order to modify the grid line spacing?
Posted: 1 decade ago 2012年3月9日 GMT+1 21:35
Does anyone have an answer for this, changing the grid/axes settings for views in 4.2?
Russell
Does anyone have an answer for this, changing the grid/axes settings for views in 4.2? Thanks, Russell
