2011年4月6日 GMT+2 07:53
there are two things I believe is not optimum: First you use edge loads and not boundary loads, this easily over stresses locally the model, particularly with the very coarse mesh you are using.
Second the forces appear tangent to the surfaces, which might make it slightly tricky to load and for the solver to start
Another remark, I'm astonished that your model has the load section positioned at the Y direction at different heights, your model is not really symmetric like that, you are combining force and moment loads
My experience so far is that ANSYS and COMSOL (as well as NASTRAN) gives similar results for the same models, its only that often its tricky to ensure the models are really the same
Well I played a little with a model I reconstructed, first I'm using a soft spring at the COG (via "Edge Load 1" which is less strict than the disabled Fixed Constraint 1) to hold it in place an to avoid it runs away, then I load it symmetrically, there are different tests in there,
I do not get any large difference between edge or boundary load for Study 1 enable the "Boundary Load 1" (or the "Edge Load 2" but not both) and check that "Prescribed Displacement 3" is disabled.
For "Study 2" disable both "Body Load 1 and Edge Load 2" and enable "Prescribed Displacement 3"
The "Prescribed Displacement 1" might not be required but it's there to enforce the symmetry (or rather antisymmetry of the two sides.
I agree that in Linear Elastic the load gets high, but I'm also using a coarse mesh 2k nodes only, "Extremely fine" is probably better. I have noticed some convergence issues with Elastoplastic material model, one would need to use much smaller parametric sweep steps to help the solver finds it's way.
The issue is not solved, anyhow you differences could well come from the elastoplastic material model parameters, or the physics behind
2011年4月6日 GMT+2 23:46
Ivar,
Thank you for your suggestions and prompt response. I had previously tried switching between edge and boundary loads in case of some local stress spike, but as you found, there was no significant difference. I have not tried an extremely fine mesh with the linear elastic model, but I have with the Elastoplastic model. It took about a week and a half solving and ended in the error: "Failed to compute Elastoplastic strain variables. Returned solution has not converged." Does this mean I need smaller parametric sweep steps?
I was also wondering if you could clarify the last statement that you made about the differences possibly coming from the Elastoplastic material model parameters, or the physics behind. Are the parameters you are referring to the inputs in the Elastoplastic model (i.e. Young's modulus, tangent modulus)? And by the physics, do you mean the governing equations in the Elastoplastic model? Do I have to somehow tweak the equations?
Thanks for your time and help,
Shannon
Ivar,
Shannon
2011年4月7日 GMT+2 07:58
no I have not "gone behind" on the elastoplastic model, you have quite some info in the doc, and by studying the "equations" used by COMSOL (turn them on in the preferences in V4).
What I suspect is that there might be differences between ANSYS and COMSOL in the way these are introduced/simplified, I tend to trust more COMSOL, as its open.
I'm currently fighting (and loosing quite some time) with large deformation and parametric sweep on torque load cases, still not understanding why the solver has such issues to find it's way, and the default logger info is very sparse.
I can confirm that imposing small increments makes often the solver go faster, as it gets less lost and uses less internal steps per demanded steps, so globally it's quicker. I just do not know how to define the optimum (yet ;)
