Applying waveform on Magnetic Field Insulation boundary
In my Magnetic Field Physics, I want to perform a Time-Domain study. I use the "Magnetic Isolation" Boundary as the place to apply a "Magnetic Field". I previously define a waveform function of sinusoidal type. It is defined as a variable called "wv1". It seems that COMSOL does not recognize "wv1" when I introduce it as the value of the magnetic field along one particular direction (e.g. Hx in A/m) in the Setup of the "Magnetic Field" interface. Is there a mean to apply a time-dependent magnetic field predefined function on an Isolation Boundary used to generate a Magnetic Field, please?
Thanks in advance! Have a nice day! David
3 Replies Last Post 2018年3月2日 GMT+1 18:06
Posted: 8 years ago 2018年3月2日 GMT+1 14:33
Updated: 8 years ago 2018年3月2日 GMT+1 14:34
Did you remember to pass time as an argument to the function when you call it?
wv1(t)
Did you remember to pass time as an argument to the function when you call it? wv1(t) Jeff
Posted: 8 years ago 2018年3月2日 GMT+1 15:46
Hello Jeff! Thank you for your prompt answer. I changed a bit my geometry and integrated a Coil to generate the magnetic field. (I got rid of the magnetic field replacing the Magnetic Insulation Boundary). I had the same trouble when I write wv1 in the Coil current: COMSOL did not know this variable :( I've tried passing the time as argument and writing wv1(t) in the Coil current but still got into trouble: COMSOL said there is an issue with the Units :(
Then I created an analytic function such as: an1(t) = 0 + wv1(t) And now I can associate it with the coil current!!! COMSOL accepts it as the Coil current :)
I will go further and try to apply it on an Magnetic Isolation boundary replaced by a Magnetic Field from an1(t).
Best regards, David
Hello Jeff! Thank you for your prompt answer. I changed a bit my geometry and integrated a Coil to generate the magnetic field. (I got rid of the magnetic field replacing the Magnetic Insulation Boundary). I had the same trouble when I write wv1 in the Coil current: COMSOL did not know this variable :( I've tried passing the time as argument and writing wv1(t) in the Coil current but still got into trouble: COMSOL said there is an issue with the Units :( Then I created an analytic function such as: an1(t) = 0 + wv1(t) And now I can associate it with the coil current!!! COMSOL accepts it as the Coil current :) I will go further and try to apply it on an Magnetic Isolation boundary replaced by a Magnetic Field from an1(t). Best regards, David
Posted: 8 years ago 2018年3月2日 GMT+1 18:06
Hello Jeff!
I tried to apply the analytic function an1(t) on the Magnetic Isolation replaced by "Magnetic field" and it works! I wrote an1(t) in the Hx coordinates. Strangely it does not work with the waveform function wv1(t).
Regards, David
Hello Jeff! I tried to apply the analytic function an1(t) on the Magnetic Isolation replaced by "Magnetic field" and it works! I wrote an1(t) in the Hx coordinates. Strangely it does not work with the waveform function wv1(t). Regards, David
