Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
7 years ago
2018年3月14日 GMT+1 18:54
Depends on a lot of factors; predominantly how complex the geometry is. Have you tried a simpler geometry first to make sure that the import process is working correctly for you ? Do you have the actual model file that we can look at that gives you the problem ? Have you tried tweaking the tolerance levels on the options when you import ?
James D. Freels, Ph.D., P.E.
7 years ago
2018年3月14日 GMT+1 21:22
Hi Jim,
Thanks for reply. The model, in general, does not belong to me so I cannot share it. For better follow-up for other users, however, I want to emphasize two points.
The geometry I have is a basic one, so I do not think the problem is complexity for my case. I assume the export problems may result in problematic surface on my geometry, which is a problem of CAD software. Recently, I created similar geometry in COMSOL and I succeeded to form an assembly out of it.
Second point is that when I adjust the tolerance levels, warnings keep coming for CAD exported geometry. I will make sure the CAD model is right and will post here the results for others who may need so.
Thank you again,
Bera
Bera
Hi Jim,
Thank you again,
Bera
