How to export a deformed shell?
Is there any way to export a bent shell from a structural mechanics simulation? I really need to know how I can do so?Remesh deformed configurationjust works for solid and not the shell. Do you have any idea?
Kind regards
2 Replies Last Post 2018年5月3日 GMT+2 23:42
Josh Thomas Certified Consultant
Posted: 7 years ago 2018年5月3日 GMT+2 23:17
Updated: 7 years ago 2018年5月3日 GMT+2 23:18
Shaghayegh-
The remesh deformed configuration option only works on a volumetric mesh so it won't work on the 3D surface mesh (as you've discovered). A workaround here would be to export a 3D plot (with deformation) of your shell analysis as an STL file.
This technique is explained here by Temesgen Kindo (see end of his blog):
www.comsol.com/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/
I've used this technique. It works great.
Have fun!
Josh Thomas
AltaSim Technologies
Shaghayegh- The remesh deformed configuration option only works on a volumetric mesh so it won't work on the 3D surface mesh (as you've discovered). A workaround here would be to export a 3D plot (with deformation) of your shell analysis as an STL file. This technique is explained here by Temesgen Kindo (see end of his blog): www.comsol.com/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/ I've used this technique. It works great. Have fun!
Posted: 7 years ago 2018年5月3日 GMT+2 23:42
Dear Josh,
Thanks a lot! this is exactly what I want! I greatly appreciate your help.
Best wishes, Shaghayegh
Dear Josh, Thanks a lot! this is exactly what I want! I greatly appreciate your help. Best wishes, Shaghayegh
