Yara Soares
COMSOL Employee
7 years ago
2018年5月11日 GMT+2 14:09
Dear Roozbeh,
If you haven't gotten a reply back, please consider submitting your question to support@comsol.com for a swift reply.
Met vriendelijke groet, Best regards,
Yara Soares
COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212
www.comsol.nl | yara.soares@comsol.com
Dear Roozbeh, If you haven't gotten a reply back, please consider submitting your question to support@comsol.com for a swift reply. Met vriendelijke groet, Best regards, Yara Soares -------------------------------------------------------------------------- COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212 www.comsol.nl | yara.soares@comsol.com --------------------------------------------------------------------------
7 years ago
2018年5月14日 GMT+2 11:22
Easiest would have been if there was a livelink product that links Avizo to comsol. That you may check.
However, there are 3D import formats such as stl or 3D-CAD and probably more depending on the livelink products that you have. If you can export your geometry to any of these, then you can directly import them from GUI.
On the other hand, if you just want to load different regular geometries such as spheres or cylinders, you can easily load them from MATLAB. For example, to create the code, use GUI and generate a cylinder by giving its properties. Then save as 'm' file. When you inspect the m file it is easy to understand the script. You now add a do loop around the script by varying the coordinates and dimensions of the cylinder, for which you already have data from your other software. But be careful of how many such cylinders you have. If you say thousands of them, it is not at all efficient because you may be successful in loading the geometry (time consuming) but how are you going to ensure that when cylinders meet each other, their geometry is smoothly interfaced for each and every such interface. You might face an uphill task as well when it comes to meshing - in all probability your mesh may break down. I say this from experience of loading 10,000 spheres, where I ended up with degenerate geometry because of 100s of overlapping or nearly touching spheres, which also gave problems with meshing. Manually fixing them in GUI is an impossibel task. So as long as your geometry is neat, you are fine. My best advise is as Yara says, speak to COMSOL support.
Of course, it will be nice to know if you succeed and how you did it.
Suresh
Hi, Easiest would have been if there was a livelink product that links Avizo to comsol. That you may check. However, there are 3D import formats such as stl or 3D-CAD and probably more depending on the livelink products that you have. If you can export your geometry to any of these, then you can directly import them from GUI. On the other hand, if you just want to load different regular geometries such as spheres or cylinders, you can easily load them from MATLAB. For example, to create the code, use GUI and generate a cylinder by giving its properties. Then save as 'm' file. When you inspect the m file it is easy to understand the script. You now add a do loop around the script by varying the coordinates and dimensions of the cylinder, for which you already have data from your other software. But be careful of how many such cylinders you have. If you say thousands of them, it is not at all efficient because you may be successful in loading the geometry (time consuming) but how are you going to ensure that when cylinders meet each other, their geometry is smoothly interfaced for each and every such interface. You might face an uphill task as well when it comes to meshing - in all probability your mesh may break down. I say this from experience of loading 10,000 spheres, where I ended up with degenerate geometry because of 100s of overlapping or nearly touching spheres, which also gave problems with meshing. Manually fixing them in GUI is an impossibel task. So as long as your geometry is neat, you are fine. My best advise is as Yara says, speak to COMSOL support. Of course, it will be nice to know if you succeed and how you did it. Suresh
