ParametricSweep WITH AdaptiveMesh
I solve the temperature in a rectangle, with temperature given on the boudaries. The temperature T(x,y) is solved with "Adaptive Mesh Refinement". Then, many rectangles with different "Heigth" are solved with a "Parametric Sweep".
The problem is that the solutions stored are the solution with the initial mesh of each geometrie, but i cant find the solution obtained with the adapted mesh for those geometrie.
Can anyone tell me what I have to do to store the "adapted mesh" result, for each geometrie of the parametric sweep ?
I joined the .mph.
Thank you.
Université Laval
3 Replies Last Post 2011年5月5日 GMT+2 16:37
Posted: 1 decade ago 2011年5月4日 GMT+2 22:31
I would like to know if someone have any idea about the subject before I surrender this thread.
thank you.
Université Laval
I would like to know if someone have any idea about the subject before I surrender this thread. thank you. ---------------- Université Laval
Posted: 1 decade ago 2011年5月5日 GMT+2 15:04
it's a tricky issue, havent played that way, but I do understand your logic, have you tried support ?
Hi it's a tricky issue, havent played that way, but I do understand your logic, have you tried support ? -- Good luck Ivar
Posted: 1 decade ago 2011年5月5日 GMT+2 16:37
I got an answer from support; it is not yet possible to combine both.
"Unfortunately, it is not currently possible to combine adaptive mesh
refinement with parametric sweep. This is a feature that we are looking at
implementing. However, it is not yet certain which release it will be in."
I'm glad they are looking at it at least.
Université Laval
I got an answer from support; it is not yet possible to combine both. "Unfortunately, it is not currently possible to combine adaptive mesh refinement with parametric sweep. This is a feature that we are looking at implementing. However, it is not yet certain which release it will be in." I'm glad they are looking at it at least. ---------------- Université Laval
