2011年5月4日 GMT+2 17:32
Yeah,
You can define a surface and ask the solver to integrate over that specific surface.
Cheers
Yeah,
Cheers
2011年5月5日 GMT+2 07:42
You are right,
it is possible to define a surface being bounded by geometric entities.
What I want is to define a surface whose boundaries depend on the value of a variable which was solved for before.
Marcel
You are right,
Marcel
2011年5月5日 GMT+2 10:23
You want to average the pressure of a part of a boundaray, which has a temperature higher than a reference temperature 'Tref'?
Not tested:
integrate the following expression over the boundary:
(T>=Tref)
result: length/area of the part of the boundary.
next: integrate the following expression over the boundary:
(T>=Tref)*p
divide the result of B by A. That's what you want?
best regards
Not tested:
(T>=Tref)
(T>=Tref)*p
best regards
2011年5月5日 GMT+2 11:01
Thanks for your answer.
With result A I get the area on the boundary where T>Tref.
Integrating the whole surface and just multiplying (T>Tref) simply uses a value of zero when T<Tref and the average value is far too low.
Marcel
2011年5月5日 GMT+2 15:14
yes there is the fact that an average divides by the full area, so you need to do two separate integrations and make the division manually (or on the same line) and not use "average"
