fluid mechanics - output to input
Hello
I hope someone can help me with the next problem. Im buliding a simple (3D) geometry of a square channel with input in the one end, and output at the other. My question is how would i put the output result of speed and concentration to the input of the next simulation of the channel of the same size. Basically i'm just trying to cut my model to individual regions and proces them seperatly.
Any help is appreciated, thanks.
2 Replies Last Post 2012年2月16日 GMT+1 19:37
Posted: 1 decade ago 2011年5月5日 GMT+2 16:00
if you are in the same model file, you might use a coupling projection operator (check Definitions) or store the results and define initial conditions from there ...
Hi if you are in the same model file, you might use a coupling projection operator (check Definitions) or store the results and define initial conditions from there ... -- Good luck Ivar
Posted: 1 decade ago 2012年2月16日 GMT+1 19:37
I'm working with a similar problem , did you solve that problem of yours by any chance??. If you did could you please indicate me how?? . Thanks anyway
Hi I'm working with a similar problem , did you solve that problem of yours by any chance??. If you did could you please indicate me how?? . Thanks anyway
