Mode analysis - changing refractive index
I am currently doing a mode analysis and need to do a simulation with different refractive index. I want
the refractive index for one region in my geometric model to vary between '2 + eps' to '2 - eps'. How can I
do this the best way?
Is it possible to .. create a parameter 'nd' = 2, and then another parameter 'deps' = 0. Next step is creating a function called 'n_func(deps)', in which is equal to 'n_func = nd + deps'. Then I create a parametric sweep for variable called 'deps' between [2 + eps, 2 - eps] and placing n_func(deps) in the refractive index input for that material of the wanted region?
The problem is I dont get the same result (same refractive index and nodes) for when deps = 0, that is when nd = 2 = n_func(deps). As far as I can see I haven't changed the two files that much other than adding n_func to the one of the files.
Is there a way to save the resulting effective refractive index per n_func(deps) as vector text file or similar to be opened in matlab?
Many thanks for any assistance.
3 Replies Last Post 2011年5月13日 GMT+2 22:42
Posted: 1 decade ago 2011年5月6日 GMT+2 13:57
first of all "eps" is already a COMSOL internal variable, use something else, my way would be:
Global Definitions Parameter deps = 0
Material property or "physics material property user defined" index value n = 2+deps
Solver: add Parametric sweep on parameter deps = 0.2*range(-1,0.1,1)
The latter you can do by either add a "Study Parametric Sweep" or at the sub node level: Stationary Solver 1, add Parametric
Hi first of all "eps" is already a COMSOL internal variable, use something else, my way would be: Global Definitions Parameter deps = 0 Material property or "physics material property user defined" index value n = 2+deps Solver: add Parametric sweep on parameter deps = 0.2*range(-1,0.1,1) The latter you can do by either add a "Study Parametric Sweep" or at the sub node level: Stationary Solver 1, add Parametric -- Good luck Ivar
Posted: 1 decade ago 2011年5月13日 GMT+2 13:47
Thank you!
One more question. How do you do parametric sweep twice but for different parameters? Is it possible?
Will it play out as like for two for-loops, i.e
for i = 1: 3
for j = 1: 5
-- text --
end
end
[QUOTE] Hi first of all "eps" is already a COMSOL internal variable, use something else, my way would be: Global Definitions Parameter deps = 0 Material property or "physics material property user defined" index value n = 2+deps Solver: add Parametric sweep on parameter deps = 0.2*range(-1,0.1,1) The latter you can do by either add a "Study Parametric Sweep" or at the sub node level: Stationary Solver 1, add Parametric -- Good luck Ivar [/QUOTE] Thank you! One more question. How do you do parametric sweep twice but for different parameters? Is it possible? Will it play out as like for two for-loops, i.e for i = 1: 3 for j = 1: 5 -- text -- end end
Posted: 1 decade ago 2011年5月13日 GMT+2 22:42
in the parametric (or continuation) sweep, you add two or more parameter names, then the raneg netry must be sorted in pair, triplets (check the doc and the forum, there have already been many discussions and examples about this (use the "search" function)
Hi in the parametric (or continuation) sweep, you add two or more parameter names, then the raneg netry must be sorted in pair, triplets (check the doc and the forum, there have already been many discussions and examples about this (use the "search" function) -- Good luck Ivar
