2 decades ago
2009年11月27日 GMT+1 16:08
I got those messages also the other day, I was wrking in assembly mode, with "no imprints" and had defined bounary conditions with bolean limits, using ALE on one side of the geometry, with force analysis on one part.
When I mesh coarse I get the message, by meshing finer they did not appear.
From what I got out, was that some of the ALE nodes were moving in and out of my boundary conditions settings, the solver detected that it should also inlcude/substract new/old nodes for the force clculations, but it was not able to "on the fly" during solving. The force measurements were also somewhat wrong, but the rest seemed to solve OK.
by decreasing mesh size, I did not get any warnings and the results seemd better.
Normally I start with a coarse mesh, and decrease until I have less than 10% changes on the results, while I check the warnings and other
Hope this helps
Hope this helps
2 decades ago
2009年11月27日 GMT+1 16:36
Hi Steven and Ivar. The warning messsage in itself can be considered a bug. It does not affect the reliability of your solution.
For details see
www.comsol.com/support/knowledgebase/1056/
Niklas
For details see
http://www.comsol.com/support/knowledgebase/1056/
Niklas
2 decades ago
2009年11月27日 GMT+1 17:03
Hello Niklas
Well I though there were no bugs in COMSOL ;)
In fact you confirm what I suspected, as I was interested in the reaction forces, I will continue to take some cautions when such warnings appear, but as I said above, the results were reasonnable, therefore I was, and I'm still not, alarmed, but ... warned.
have a nice week-end
Hello Niklas
2011年3月8日 GMT+1 17:41
If this was a bug in 2009, is it then "re introduced" in 4.1 ?
I keep getting this warning now in a fairly simple turbulent model.
2011年3月8日 GMT+1 21:25
It's not a bug, in my view, it's a is says a warning, and warnings are to be analysed to see if they interact with your model results, In some cases it could be dramatic, even if mostly it's harmless.
Fo me so far it is linked to the ALE and the large displacements observed over boundaries with exrternal force/flux conditions
Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
2011年3月9日 GMT+1 04:16
My approach to this problem, but do not actually know for sure is to consider the check box that can be unchecked to evaluate reaction forces. That is what I do to eliminate this warning message. Unless you need to actually know the reactionary forces, it is not needed.
2011年3月15日 GMT+1 10:54
Thanks for this help, I have the same problem, but not with an ALE model. I will try again first with a finer mesh and second by uncheck this box.
I'll keep you in touch
regards
Jérémie GIRARDOT
regards
Jérémie GIRARDOT
