Biot Poroelasticity coupling
i want to simulate the Biot Poroelasticity problem in comsol 4.1 using the solid mechanics interface and PDE interface instead of the poroelastiity interface, because the poroelastiity interface can't solve all my question. bu i found that in this case the volumatic strain(solid.evol) is constant ,it didn't changing with time. so it was not fully coupled, only flow can influce deformation, deformation can not influce the flow, why?
thanks
5 Replies Last Post 2017年5月15日 GMT+2 08:55
Hello J Yuan
Posted: 1 decade ago 2011年7月26日 GMT+2 17:23
It is possible. I have done it in version 4.2, coupling linear elastic with transient Darcy's law. What I have done is tried to recreate the biot-poroelasticity example available in comsol model library. The results look more or less identical, but you may like to check. If you find mistakes, you can let me know.
I did this in Earth sciences module. I don't have the structural mechanics module.
Hope this helps.
Suresh
It is possible. I have done it in version 4.2, coupling linear elastic with transient Darcy's law. What I have done is tried to recreate the biot-poroelasticity example available in comsol model library. The results look more or less identical, but you may like to check. If you find mistakes, you can let me know. I did this in Earth sciences module. I don't have the structural mechanics module. Hope this helps. Suresh
Posted: 1 decade ago 2011年7月26日 GMT+2 18:42
thank you for you kindly replay, yes it is possible to use the biot proroelasticity in comsol library. but for my problem i have to rewrite the darcy's equation since my equation is different from darcy', so i use the PDE module to instead Darcy's law and coupling with linear elastic. and i have solved this problem in 2-D. but in the 3-D model i ofen have this erro:
Error:
Failed to find consistent initial values.
Last time step is not converged.
the boundaries conditon and properties are same as the 2-D problems
thank you for you kindly replay, yes it is possible to use the biot proroelasticity in comsol library. but for my problem i have to rewrite the darcy's equation since my equation is different from darcy', so i use the PDE module to instead Darcy's law and coupling with linear elastic. and i have solved this problem in 2-D. but in the 3-D model i ofen have this erro: Error: Failed to find consistent initial values. Last time step is not converged. the boundaries conditon and properties are same as the 2-D problems
Posted: 8 years ago 2017年5月15日 GMT+2 08:41
Hi Yuan
Have you solved the problem?
I also want to have a test of building the poroelastic problem from PDE equations.
Could you send me a mph file of simplest 2d example?
Thank you!
Zhang
Error:
Hi Yuan Have you solved the problem? I also want to have a test of building the poroelastic problem from PDE equations. Could you send me a mph file of simplest 2d example? Thank you! Zhang [QUOTE] thank you for you kindly replay, yes it is possible to use the biot proroelasticity in comsol library. but for my problem i have to rewrite the darcy's equation since my equation is different from darcy', so i use the PDE module to instead Darcy's law and coupling with linear elastic. and i have solved this problem in 2-D. but in the 3-D model i ofen have this erro: Error: Failed to find consistent initial values. Last time step is not converged. the boundaries conditon and properties are same as the 2-D problems [/QUOTE]
Posted: 8 years ago 2017年5月15日 GMT+2 08:45
In Suresh's mph file, I didn't see the contribution of pore pressure to mechanical deformation.
It may lack something.
Yige
Hope this helps.
Suresh
In Suresh's mph file, I didn't see the contribution of pore pressure to mechanical deformation. It may lack something. Yige [QUOTE] It is possible. I have done it in version 4.2, coupling linear elastic with transient Darcy's law. What I have done is tried to recreate the biot-poroelasticity example available in comsol model library. The results look more or less identical, but you may like to check. If you find mistakes, you can let me know. I did this in Earth sciences module. I don't have the structural mechanics module. Hope this helps. Suresh [/QUOTE]
Posted: 8 years ago 2017年5月15日 GMT+2 08:55
Oh, I am sorry.
I found the changes for pore pressure in Suresh's model, when I read the output report.
In the solid.S11, solid.S22, and solid.S33, there is a term of alpha*pf.
Hope this helps.
Suresh
Oh, I am sorry. I found the changes for pore pressure in Suresh's model, when I read the output report. In the solid.S11, solid.S22, and solid.S33, there is a term of alpha*pf. [QUOTE] It is possible. I have done it in version 4.2, coupling linear elastic with transient Darcy's law. What I have done is tried to recreate the biot-poroelasticity example available in comsol model library. The results look more or less identical, but you may like to check. If you find mistakes, you can let me know. I did this in Earth sciences module. I don't have the structural mechanics module. Hope this helps. Suresh [/QUOTE]
