Connecting two physics
[start here]hi, i want to add the capictor from electrical circuit to the electron beam simulation in particle tracing module to check wether it is chaging or not
1 Reply Last Post 2018年7月30日 GMT+2 11:13
Posted: 7 years ago 2018年7月30日 GMT+2 11:13
Hi Varun,
To connect two physics go to your second study -> step -> Values of dependent variables. Check the box "Values of variables not solved for" and select solution in "method" and in "study" select the other 1st study
Hope this helps,
Nichal
Hi Varun, To connect two physics go to your second study -> step -> Values of dependent variables. Check the box "Values of variables not solved for" and select solution in "method" and in "study" select the other 1st study Hope this helps, Best, Nichal
