joule heating via current density
Dear comsol users,
I do a lot of modelling in AC/DC-Module. Now I have a axisymmetric model of a electromagnetic actuator in which I want to calcualte the heat distribution. The heat source is the coil of the actuator. I attempted to apply an external current density on the coil domain, but I doesn`t work at all. I also tryed in 3D mode, same problem. In 3D it is also possible to apply electric Potentials to boundaries. Doing so I get a temperaturdistribution as solution. But there is no way to do so in a axisymmetric model. I added my model so u can try yourself.
So my question is: Why isn´t a current flowing if an external current density is used on a domain?
Please help, best regards
Oliver
2 Replies Last Post 2015年10月2日 GMT+2 14:25
Hello Oliver Vogel
Posted: 1 decade ago 2015年9月23日 GMT+2 23:29
Did you ever determine a method to do this analysis? I am currently trying to figure out a similar problem. I am trying to determine the heat produced from a coil with a constant current being applied.
Any help would be appreciated.
Very Respectfully,
Will
Hello, Did you ever determine a method to do this analysis? I am currently trying to figure out a similar problem. I am trying to determine the heat produced from a coil with a constant current being applied. Any help would be appreciated. Very Respectfully, Will
Posted: 1 decade ago 2015年10月2日 GMT+2 14:25
Hi Will,
sorry for late response, but I was unable to log in to my comsol account, maybe expired...
Actually I was able to do a thermal analysis.
I atached an exemplary model, wher you can see how I did it.
Maybe it is not exactly what you need but you can surely adapt some conditions and ideas.
Best regards
Oliver
P.S.: I am still working with version 4.3
Hi Will, sorry for late response, but I was unable to log in to my comsol account, maybe expired... Actually I was able to do a thermal analysis. I atached an exemplary model, wher you can see how I did it. Maybe it is not exactly what you need but you can surely adapt some conditions and ideas. Best regards Oliver P.S.: I am still working with version 4.3
