X Window System error
Hi Everyone,
I just installed new 4.2 Comsol, when I try to launch it the windows disappears in 1second!
with this message :
he program 'SWT' received an X Window System error.
This probably reflects a bug in the program.
The error was '255'.
(Details: serial 5595 error_code 255 request_code 143 minor_code 17)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
I follow this topic, but it does not work..
www.comsol.asia/community/forums/general/thread/18493/
Anyone else has this problem and could help me...
Regards.
Idir
1 Reply Last Post 2011年7月5日 GMT+2 13:42
Posted: 1 decade ago 2011年7月5日 GMT+2 13:42
same problem here on ubuntu 10lts.
the line "graphics.rendering.2drend=swing" is removed from the config after the startup-crash. it works on an other machine also running ubuntu 10lts.
same problem here on ubuntu 10lts. the line "graphics.rendering.2drend=swing" is removed from the config after the startup-crash. it works on an other machine also running ubuntu 10lts.
