Hello Imran Ibrahim
                                8 years ago
                                2016年9月27日 GMT+2 11:47
                                                    Hi...
i try to module the electricall double layer, using electrostatic et transport of diluted species module but I cannot successfully implement the surface charge in boundary condition and i had the same problem and it seem the same msg error :
Attempt to evaluate negative power of zero.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.Surf_Charge_Density@VDN$comp1.phi
- Defined as: (((comp1.CONST7^(-0.5))*0.5)*((-((-(((((exp((-comp1.phi)/V_therm)*(-(1/V_therm)))*cA_bulk)*CONST1)*a3)*comp1.CONST3))*(1/(1-(comp1.CONST3*(a3*comp1.NS_positif))))))*CONST2))*e_const
- Variable: comp1.es.sfcd1.rhoqs@VDN$comp1.phi
- Expression: ((-((((comp1.CONST7^(-0.5))*0.5)*((-((-(((((exp((-comp1.phi)/V_therm)*(-(1/V_therm)))*cA_bulk)*CONST1)*a3)*comp1.CONST3))*(1/(1-(comp1.CONST3*(a3*comp1.NS_positif))))))*CONST2))*e_const))*comp1.es.d)*dvol
Failed to evaluate Jacobian of expression.
- Expression: (comp1.es.d*(-comp1.es.sfcd1.rhoqs))*dvol
- Expression: (-comp1.es.sfcd1.rhoqs*test(comp1.phi)*comp1.es.d)*(dvol)
- Feature: Stationary Solver 1 (sol3/s1)
so please did you find a solution and how can i fix it
Appreciate much for your help!!
                            Hi...
- Function: ^
