How to insert electric field as variable in a formula
I an using coefficient form PDE and some of the equations i am using are directly related to the electric field (i.e. variable of electric field) I would like to know how to insert variable electric field in a formula. i used "es.normE & sqrt(es.Exes.Ex+es.Eyes.Ey+es.Ezes.Ez)", but in both the cases it says undefined variable.
with regards Hari
1 Reply Last Post 2018年8月1日 GMT+2 15:36
Posted: 7 years ago 2018年8月1日 GMT+2 15:36
Hi Hari,
Are you using the electric currents module? If yes the correct name is "ec.normE". If not try to use the physics identifier (ht for heat transfer, jh for joule heating, etc). Of course that your physics should have an electric field
Nichal
Hi Hari, Are you using the electric currents module? If yes the correct name is "ec.normE". If not try to use the physics identifier (ht for heat transfer, jh for joule heating, etc). Of course that your physics should have an electric field Best, Nichal
