Assembling of matrix takes very long
Hello!
I'm trying to solve a (quite simple) 2D-axissym. model of a fixed bed reactor. I have four species where only three a actually taking part in the exothermic reaction. The chemistry is modeled in re (reaction engineering module) and exported to the 2D-model where I use the following modules: tds (transport diluted species), ht (heat transfer in fluids) and br (Brinkmann-equations).
As far as I can see, I set up the model correctly. But when I want to solve it, it takes hours to assemble the matrix!!!
Is this a normal behaviour? Or where could I start finding the mistake?
Thanks in advance! Till
4 Replies Last Post 2018年9月24日 GMT+2 11:14
Posted: 7 years ago 2018年9月21日 GMT+2 13:47
Found an interesting behaviour:
I simplified the calculation of the heat capacity of the mixture. I left out the temperature-pendency of the species and took averaged values.
Now it solves much much faster!
Found an interesting behaviour: I simplified the calculation of the heat capacity of the mixture. I left out the temperature-pendency of the species and took averaged values. Now it solves much much faster!
Posted: 7 years ago 2018年9月21日 GMT+2 15:25
Till,
that's not too surprising. A temperature dependent heat capacity makes the heat transfer physics nonlinear.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Till, that's not too surprising. A temperature dependent heat capacity makes the heat transfer physics nonlinear. Cheers Edgar
Posted: 7 years ago 2018年9月24日 GMT+2 10:04
Hi Edgar,
thanks for replying. But is this the effect that strong? Computing a solution with fixed Cp takes about 1 minute. With Cp(T) it takes several hours! BTW: I have modeled the heat conductivity also as a function of T in both cases. This doesn't affect the solution time at all...?
Cheers Till
Hi Edgar, thanks for replying. But is this the effect that strong? Computing a solution with fixed Cp takes about 1 minute. With Cp(T) it takes several hours! BTW: I have modeled the heat conductivity also as a function of T in both cases. This doesn't affect the solution time at all...? Cheers Till
Posted: 7 years ago 2018年9月24日 GMT+2 11:14
Till,
yes that is at least a little surprising. Is the derivative Cp(T)/dT nicely smooth?
Cheers Edgar
Edgar J. Kaiser
www.emphys.com
Till, yes that is at least a little surprising. Is the derivative Cp(T)/dT nicely smooth? Cheers Edgar
