Parametric sweep
I defined a parameter at global definitions (Name: para; Expression: 1).
My inflow heat flux depends on the daytime and the emission coefficient - so i defined the Inflow heat flux as a sine function of time multiplied by "para".
I added at "Parametric sweep" the parameter "para" and defined the range to be take into consideration as (range(0.1,0.1,1).
By trying to solve i get the Error: "Error in sweep: Parameter names must not be empty".
But: The parameter names are not empty. What have I done wrong?
NR
1 Reply Last Post 2011年7月27日 GMT+2 09:02
Michael Rembe Certified Consultant
Posted: 1 decade ago 2011年7月27日 GMT+2 09:02
I don't know, if I understand your problem correctly. I use "Extension" from the stationary solver and activate "continuation". Choose the parameter ....
It works different from parametric sweep.
Michael
I don't know, if I understand your problem correctly. I use "Extension" from the stationary solver and activate "continuation". Choose the parameter .... It works different from parametric sweep. Michael
