Hello Qingyi Han
2012年9月21日 GMT+2 19:54
I am facing the same problem. Did you resolve it out? could you please explain me a little. I would appreciate your help.
Thanks a lot in advance.
-Cheers
Hemant
-Cheers
Hemant
2012年9月21日 GMT+2 21:06
I think that my problem was resolved, but it's been a long time ago, so I can't remember exactly.
However, there may be a couple of things you can try:
- check the available place in your disc.
- remove all the files created automatically by comsol (there is a .comsol file somewhere, sometimes hidden, so you should change the status of your file browser).
Here are all I can say for now. Let me know.
Good luck,
QH
Good luck,
QH
2012年9月22日 GMT+2 20:44
Hello QH,
Thanks a lot for the reply.
I have tried several things including,
1. Deleting all the temp files form my desktop using a tool called ccleaner. I have deleted .comsol files present in my user profile.
2. I created a temporary folder (in an external 500 GB drive) to redirect the comsol temp files to avoid memory outages. I changed the comsol.ini file to achieve this.
3. I have a 16GB RAM workstation which is ready to be used
Nothing has worked out so far. Do you have any other suggestion?
-Cheers
Hemant
Hello QH,
-Cheers
Hemant
2012年9月26日 GMT+2 23:38
Hi Hemant,
In this case, maybe the error has nothing to do with the saving profile.
I remember that I had a lot of problems with the CAD import module, which can cause some wired internal errors.
Actually, my work was to import some human body geometries in format .stp from Catia V5.
During my work, at every step I checked everything and saved the file before making further changes, which allowed me to do backward in case of problem.
If you are doing the same work, I think you won't have choice to do it over, because in this case, the problem is much more complicated.
QH
Hi Hemant,
QH
