Unexpected Complex Frequencies in Acoustic Eigenfrequency Solver
Posted 2018年11月4日 GMT+1 02:14 Acoustics & Vibrations Version 5.4 1 Reply
I have a simple 3D model, with which I'm analyzing the phononic band structure, similar to this blog post: https://www.comsol.com/blogs/modeling-phononic-band-gap-materials-and-structures/. I'm seeing some odd behavior near zero frequency solutions, and I believe the problem can reduced to a simpler problem, stated below.
In my 3D model, I impose periodic boundary conditions on each opposing side. When solving the pressure acoustics equation, there should clearly be a trivial constant pressure solution, with eigenfrequency zero. When solving for the eigenfrequency, however, I get an eigenfrequency of around 0.7 + 100i Hz. While I'd normally brush this off as an unimportent numerical error, the abnormaly-large imaginary part persists in analyzing the band structure for finite wavevectors, and gives me non-physical solutions when I try looking at the bandstructure at small frequencies. What could be causing these complex frequencies, and how can I address them?
