Nagi Elabbasi
Facebook Reality Labs
2011年8月11日 GMT+2 23:33
If you want a radial force change the load type of the Boundary Load to Pressure.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
2011年8月13日 GMT+2 19:33
You can probably also define, in your case, a cylindrical coordinates check the Definitions node
2011年8月16日 GMT+2 12:21
Thanks, this is exactly what I needed.
Now a different problem, but related: I have defined a cylindrical coordinate system and added a Body Load. I need the Body Load to have an r-component that depends on r.
By which I mean, Body Load has three components, r, phi, a. For the r component, I have some expression that consists of a bunch of constants multiplied by r. So the force per volume element is (constants)*r.
How do I put "r" into the Body Load force components box?
2011年8月16日 GMT+2 12:38
[continued]
I should tell you what I have tried.
In the Force-in-r-direction box, I tried typing r, and it doesn't recognize it. I then realized it needs to be in units of N/m^3 as it says to the right of that box, so I multiply r by 1*[N/m^4] in order to just get it in the correct units (so the final expression reads r*1[N/m^4], and it doesn't recognize it. Note that I am leaving out the constants for now, I'm just multiplying by 1 for the sake of getting it working.
Next I try u*1[N/m^4] just for the heck of it even though it's not what I want. It recognizes it! However I don't want u, I want r*1[N/m^4], or sqrt(u^2+v^2)*1[N/m^5] -- where I am again multiplying by 1 with some units to make the final expression be in N/m^3. However now it appears to not like the sqrt.
So in summary:
WORKS BUT INCORRECT:
u*1[N/m^4]
u^2*1[N/m^4]
(u^2+v^2)*1[N/m^4]
DOESN'T WORK BUT WANT:
r*1[N/m^4] --- doesn't work due to the "r"
or
sqrt(u^2+v^2)*1[N/m^4] --- doesn't work due to the "sqrt"
[continued]
So in summary:
u*1[N/m^4]
u^2*1[N/m^4]
(u^2+v^2)*1[N/m^4]
or
2011年8月16日 GMT+2 15:05
Never mind! Figured it out.
I had to use x and y rather than u and v, and then it works
Also, My "sqrt" was not incorrect, rather, I typed N/m^5 rather than N/m^4 into comsol.
2011年8月17日 GMT+2 10:36
careful with your variables names:
if YOU define a variable r = sqrt(x^2+y^2) you can refer to "r", but if you define a spherical coordinate (default settings) you must refer to "sys2.r" (if its the first coordinate defined else 2 becomes 3, 4 ...)
And do not mess up the "frames" sqrt(x^2+y^2) is different from sqrt(X^2+Y^2), check the doc and play with some simple examples
