finer circle resolution
I am simulating electrical machines with the .rmm physics and was wondering, if it is somehow possible to get circles/curves with a higher resolution. When I take a close look at my air gap, I can see relatively big corners.
At first I thought this happend somehow because I imported a CAD model. But when I created a new model within the COMSOL GUI, the same problem appears. Or is it maybe just a visual problem?
Thanks in advance
2 Replies Last Post 2012年6月19日 GMT+2 11:49
Posted: 1 decade ago 2011年8月13日 GMT+2 18:55
you have different levels to check / control
1) the CAD generation and CAD import relative error (when importing external CAD geometry)
2) the grapohical rendering of COMSOl only a visual effect, check your preferences
3) the meshing resolution, during the meshing phase
1) is for me the most delicate and easy to forget, 2) is only a visula effect, but can be tricky for surface/line/point graphical selection and for your graphical display bandwidth and 3) is related to your calculations expectations (and time + RAM available)
Hope this helps
Hi you have different levels to check / control 1) the CAD generation and CAD import relative error (when importing external CAD geometry) 2) the grapohical rendering of COMSOl only a visual effect, check your preferences 3) the meshing resolution, during the meshing phase 1) is for me the most delicate and easy to forget, 2) is only a visula effect, but can be tricky for surface/line/point graphical selection and for your graphical display bandwidth and 3) is related to your calculations expectations (and time + RAM available) Hope this helps -- Good luck Ivar
Francesc-Xavier Borras
Posted: 1 decade ago 2012年6月19日 GMT+2 11:49
Hej,
I had the same problem. The problem comes when applying some Boolean Operation to this circular geometry.
It helped me to decrease the "Relative Repair Tolerance" (default 10e-6) in the option on the specific Boolean Operation (for example to 1e-12).
Hope that helps,
F. Xavier Borras
Hej, I had the same problem. The problem comes when applying some Boolean Operation to this circular geometry. It helped me to decrease the "Relative Repair Tolerance" (default 10e-6) in the option on the specific Boolean Operation (for example to 1e-12). Hope that helps, F. Xavier Borras
