increasing load
Carlos Eutimio Curiel Montoya
Hi, I'm new to COMSOL and I'm trying to simulate a beam under a load, and I want to study the effects of a increasing load from say, 0 [N] to a 100 [N], I don´t know if I can program a function to increase the force automatically or if I have to do this manually.
In the end I want to get a table that compares the input force to the resulting deflections in the beam
1 Reply Last Post 2011年8月19日 GMT+2 13:50
Posted: 1 decade ago 2011年8月19日 GMT+2 13:50
Select the stationary solver node and expand the "Extension" tab, there you can take a predefined "Parameter" and make it scan a range, and then you multiply your load by the parameter to have it changing
This implies tht you do not change your geometry, only the BCs, otherwise you need to use the "externla" Parametric Sweep functionality
Check the Forum, there are several discussion around this feature
Hi Select the stationary solver node and expand the "Extension" tab, there you can take a predefined "Parameter" and make it scan a range, and then you multiply your load by the parameter to have it changing This implies tht you do not change your geometry, only the BCs, otherwise you need to use the "externla" Parametric Sweep functionality Check the Forum, there are several discussion around this feature -- Good luck Ivar
