2011年9月5日 GMT+2 16:11
Does there anyone know how to fix this? Thank you very much in advance!
2011年9月6日 GMT+2 10:41
Hi, I think that after solving a problem data is already saved in a fem. In my opinion you should check the Matlab Interface Guide for the proper syntax.
Hoping this helps, Rafał Piotuch.
Hi, I think that after solving a problem data is already saved in a fem. In my opinion you should check the Matlab Interface Guide for the proper syntax. Hoping this helps, Rafał Piotuch.
2011年9月6日 GMT+2 12:46
Hi, Rafal,
Thank you so much for your reply. I was really try to do that, but could not find such corresponding syntax. Anyway, I would try again. Thanks.
Hi, Rafal, Thank you so much for your reply. I was really try to do that, but could not find such corresponding syntax. Anyway, I would try again. Thanks. Best regards, [QUOTE] Hi, I think that after solving a problem data is already saved in a fem. In my opinion you should check the Matlab Interface Guide for the proper syntax. Hoping this helps, Rafał Piotuch. [/QUOTE]
2011年9月7日 GMT+2 07:50
Hi - I have found it: http://www.comsol.com/community/forums/3-5a/thread/20292/ Best regards, RP
2011年9月7日 GMT+2 10:46
Thank you so much for your nice reply. I just found an alternative solution for my case. I attached my sample code here also.
S21 = [ ];
data = postglobaleval(fem,{'S21_rfwh'});
Frequency = data.x;
S21 = cat(2,S21, data.y);
Here, S21 is S-parameters, it could be also any globally defined expression.
RP
Thank you so much for your nice reply. I just found an alternative solution for my case. I attached my sample code here also. ------------------------------------------------------ S21 = [ ]; data = postglobaleval(fem,{'S21_rfwh'}); Frequency = data.x; S21 = cat(2,S21, data.y); ------------------------------------------------------- Here, S21 is S-parameters, it could be also any globally defined expression. [QUOTE] Hi - I have found it: http://www.comsol.com/community/forums/3-5a/thread/20292/ Best regards, RP [/QUOTE]
