about the error in Last time step is not converged.
Hi all:
I am a beginner in comsol. I have tried to replicate the following tutorial. I am using 3.5 version.
www.comsol.com/showroom/documentation/model/1994/
But I am always stuck in the solution step. It is good until I got the initial value at time 6e-4. But after I use this initial solution to solve the subsequent ,i.e (0, 0.5e-2, 0.08)
There is always problem. Here is error message:
Time-dependent solver/BDF
Number of degrees of freedom solved for: 142787
Nonsymmetric matrix found.
Step Time Stepsize Res Jac Sol Order Tfail NLfail
0 0 out 1 2 0 0
Error:
Failed to find consistent initial values.
Out_of_memory_in_Jacobian_computation
Anyone can help me with this? thanks a lot
1 Reply Last Post 2011年9月25日 GMT+2 06:17
Posted: 1 decade ago 2011年9月25日 GMT+2 06:17
I was having the same error :-) Changed the mesh size..Now I following error.
It may help you though.
Time-dependent solver (BDF)
Number of degrees of freedom solved for: 167464.
0 0 out 25 6 25 0
Solution time: 28 s.
I was having the same error :-) Changed the mesh size..Now I following error. It may help you though. Time-dependent solver (BDF) Number of degrees of freedom solved for: 167464. Nonsymmetric matrix found. Step Time Stepsize Res Jac Sol Order Tfail NLfail 0 0 out 25 6 25 0 Solution time: 28 s.
