Henrik Sönnerlind
COMSOL Employee
6 years ago
2019年2月14日 GMT+1 19:33
Hi Kant,
The integrated contact forces are already available as variables, so the only thing you need is the area in contact. If you integrate an expression which is 1 where there is contact and 0 elsewhere, you will find the area in contact.
The average contact force in the z-direction can thus for example be expressed as solid.T_totz/(intop1(solid.Tn>0)+eps)
The 'eps' is added to avoid a zerodivide if there is no contact.
Instead of defining your own integration operator 'intop1', you can parasitize on the one used to define solid.T_totz, and write something like
solid.T_totz/(solid.cnt1.int(solid.Tn>0)+eps)
There are also variables for the total contact forces per contact pair, with names like solid.cnt1.T_totz_p1 .
Henrik
Henrik Sönnerlind
COMSOL
Hi Kant,
The average contact force in the z-direction can thus for example be expressed as solid.T\_totz/(intop1(solid.Tn>0)+eps)
Instead of defining your own integration operator 'intop1', you can parasitize on the one used to define solid.T\_totz, and write something like
solid.T\_totz/(solid.cnt1.int(solid.Tn>0)+eps)
There are also variables for the total contact forces per contact pair, with names like solid.cnt1.T\_totz\_p1 .
Henrik
