Henrik Sönnerlind
COMSOL Employee
7 years ago
2019年3月7日 GMT+1 20:13
Hi Amin,
What you see is a 'numerical' formation of artificial shear bands.
There are some remedies:
- You can change the discretization to use linear shape functions (which of course allows you to use even more elements). Since linear shape functions imply constant stress within the element, the possibility to form this kind of pattern is reduced.
- Use a less regular mesh. Change the method to Delauney in the Free Triangular node. It will be more difficult to form this kind of patterns in an unstructured mesh.
- More advanced: Add some kind of stabilization equation which penalizes either gradients within elements or gradients over a certain distance. This is the same kind of techniques as is used in the Damage feature (new in version 5.4).
Henrik
Henrik Sönnerlind
COMSOL
Hi Amin,
* You can change the discretization to use linear shape functions (which of course allows you to use even more elements). Since linear shape functions imply constant stress within the element, the possibility to form this kind of pattern is reduced.
* Use a less regular mesh. Change the method to Delauney in the Free Triangular node. It will be more difficult to form this kind of patterns in an unstructured mesh.
* More advanced: Add some kind of stabilization equation which penalizes either gradients within elements or gradients over a certain distance. This is the same kind of techniques as is used in the Damage feature (new in version 5.4).
Henrik
7 years ago
2019年3月15日 GMT+1 04:20
Thanks a lot Henrik for the percise response! It resolved the issue.
Amin
Amin
7 years ago
2019年3月16日 GMT+1 01:08
Similar to the previous question, I want to run slope stability analysis but for an infinite slope. In order to simulate infinite slope condition, periodic boundary conditions are implemented on the lateral sides of the domain. The FS from the analytical limit state equilibrium method is computed as 2.15, and COMSOL results in the same value, as well (c’=0 Pa, phi’=30 deg, slope=15 deg).
However, the issue is that under the geostatic condition prior to slope stability analysis, by evaluating the elastic stress state, most of the soil elements have exceeded Mohr-Coulomb failure envelope (implying element failure). In this regard, why the FS is obtained more than unity indicating a stable slope while soil elements have already failed?
The model has been attached.
Thank you very much for the assistance.
