Edgar J. Kaiser
Certified Consultant
6 years ago
2019年3月8日 GMT+1 15:02
Hi Pavlos,
I guess the most straightforward solution is to add a moving mesh and control the mesh deformation with the deformation from the thermal-structural physics.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Pavlos, I guess the most straightforward solution is to add a moving mesh and control the mesh deformation with the deformation from the thermal-structural physics. Cheers Edgar
6 years ago
2019年3月8日 GMT+1 15:24
Hi Edgar,
Thanks for the advice. Actually I found a guide on how to do that and I am following that one at the moment.
Please find a link here: https://www.comsol.de/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/
I believe the other option is you said, using ALE with solid mechanics and electrostatics.
Thanks for your time.
Kind regards,
Pavlos.
Hi Edgar, Thanks for the advice. Actually I found a guide on how to do that and I am following that one at the moment. Please find a link here: https://www.comsol.de/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/ I believe the other option is you said, using ALE with solid mechanics and electrostatics. Thanks for your time. Kind regards, Pavlos.
Edgar J. Kaiser
6 years ago
2019年3月8日 GMT+1 18:04
Pavlos,
yes the manual procedure in the blog should work as well. With the ALE you can achieve a fully coupled and dynamic procedure.
Good luck Edgar
Edgar J. Kaiser
www.emphys.com
Pavlos, yes the manual procedure in the blog should work as well. With the ALE you can achieve a fully coupled and dynamic procedure. Good luck Edgar
6 years ago
2019年3月18日 GMT+1 10:33
Hi Edgar,
Thank you very much for the advice.
I will try it both ways to identify the one that suits my case best. (By using the guide, I get some errors that the mesh is problematic in some cases)
Kind regards,
Pavlos.
Hi Edgar, Thank you very much for the advice. I will try it both ways to identify the one that suits my case best. (By using the guide, I get some errors that the mesh is problematic in some cases) Kind regards, Pavlos.
