how to model ALE (solid-liquid interface) & moving boundary (topography change)? -thx
Posted 2011年10月10日 GMT+2 17:11 Heat Transfer & Phase Change, Materials Version 4.1 2 Replies
Questions
I’m a working on the modeling the laser-material interaction, which is typically a thermal one and involves phase change of melting and evaporation, recoil pressure induced by the evaporation and movement of the liquid (melting material) using Navier-Stoke. After severel weeks study and research, a lot of questions puzzle me all time. Could anyone here do me a favor to give me some suggestion and tips, thanks for your help sincerely in advance.
1. ALE
From the papers and materials in literature I have read already, ALE is a comman method to track the solid-liquid interface and liquid-gas interface. But this need to specify the displacement or velocity.
In my model, the interface is physically correlative to the temperature (melting point or evaporation temperature). The liquid-gas interface can be traced using the velocity of the liquid, but there is no velocity at the solid-liquid interface (is there any chance to use the velocity of liquid again, just like the liquid-gas interface?). In this kind of situation where there is no obvious velocity term in domain, just like the solid-liquid interface here, how to built the moving of the mesh is the most difficult problem which puzzle me a lot? Could you give me some idea? Thanks.
2. liquid volume fraction
The method of liquid volume fraction fl can distinguish the liquid and the solid, of which the value are 1 and 0 respectively. but how to plot and visualize the function puzzle me to see the different zone, though I think it is a very basic question. Could you give some idea? Thanks.
3. Moving boundary
As the laser-material interaction time go on, the bulk material will remove and a new boundary of laser-material interaction is created, ie.the laser-matterial interaction is a moving boundary. How to deal the moving boundary or the geometry change? As far as I known, the common method to change the topography or geometry is to change the matterial properties or build the geophagy with t (time). But the geography changes according to the temperature (evaporation temperature ), how and what can I do to deal with this?
Thans for you suggestion and tips very much.
Best regards to you and your family.
FM Huang
1. ALE
3. Moving boundary
FM Huang
2 Replies Last Post 2012年2月9日 GMT+1 07:35
