Poroelasticity
Hi everyone,
I have some issues with my simulation regarding a poroelastic material introduced within the female breast. I have to simulate the interaction between my scaffold, whose porosity and permeability are known, and the biological tissue. I added the Poroelasticity Multiphysics to my model, but my solution doesn't reach convergence. I'm not able to find the error. Could you help me?
I upload my model. Thanking you in advance, BR
Maria
4 Replies Last Post 2019年9月27日 GMT+2 17:12
Posted: 6 years ago 2019年9月27日 GMT+2 09:32
Unfortunately I'm not able to upload my file because it is too large.
Posted: 6 years ago 2019年9月27日 GMT+2 14:58
Updated: 6 years ago 2019年9月27日 GMT+2 15:02
Hello Maria,
What you can do to reduce the size of your file is use the "Clear All Solutions" icon on the Study ribbon and then "Save As" under a different filename (This way you still have your original, solved, file). If the file is still over 10MB, which is unlikely, you can make it even small by using the "Clear All Meshes" icon on the Mesh ribbon.
Hello Maria, What you can do to reduce the size of your file is use the "Clear All Solutions" icon on the Study ribbon and then "Save As" under a different filename (This way you still have your original, solved, file). If the file is still over 10MB, which is unlikely, you can make it even small by using the "Clear All Meshes" icon on the Mesh ribbon. Best, Jeff
Posted: 6 years ago 2019年9月27日 GMT+2 17:02
Hello Maria,
Hi Jeff,
the problem is that my file is so large because of the geometry imported from FUSION 360. Even if I try to clear all meshes and all solutions, this remains over 10MB (23MB precisely).
>Hello Maria, > >What you can do to reduce the size of your file is use the "Clear All Solutions" icon on the Study ribbon and then "Save As" under a different filename (This way you still have your original, solved, file). If the file is still over 10MB, which is unlikely, you can make it even small by using the "Clear All Meshes" icon on the Mesh ribbon. > >Best, > >Jeff Hi Jeff, the problem is that my file is so large because of the geometry imported from FUSION 360. Even if I try to clear all meshes and all solutions, this remains over 10MB (23MB precisely).
Posted: 6 years ago 2019年9月27日 GMT+2 17:12
Can you reproduce the problem with a simpler geometry?
Can you reproduce the problem with a simpler geometry? Jeff
