Impedance boundary condition of helical structure
Hi, I am trying to run some RF simulations with a helical coil. however, the surface of the helical coil is not applicable for Impedance boundary conditions. and this will lead to an error: failed to find a solution. So it is that we couldn't define an impedance boundary condition on a helical surface?
Thank you very much in advance!
2 Replies Last Post 2011年12月2日 GMT+1 10:14
Posted: 1 decade ago 2011年12月2日 GMT+1 09:49
you must remove the helical domain from the emv node. Otherwise the inside of the domain would be modeled and an impedance boundary condition makes no sense.
Cheers
Edgar
Hi, you must remove the helical domain from the emv node. Otherwise the inside of the domain would be modeled and an impedance boundary condition makes no sense. Cheers Edgar
Posted: 1 decade ago 2011年12月2日 GMT+1 10:14
Hi Edgar,
Thank you for your reply. I have already defined an explicit 'helical surface'. When the 'helical surface' is selected as the Impedance Boundary Condition, all of the boundaries of 'helical surface' are 'not applicable'.
I am trying to attach the model file here, but it is over sized.
Thank you!
Deyu
Hi Edgar, Thank you for your reply. I have already defined an explicit 'helical surface'. When the 'helical surface' is selected as the Impedance Boundary Condition, all of the boundaries of 'helical surface' are 'not applicable'. I am trying to attach the model file here, but it is over sized. Thank you! Deyu
