Failed to evaluate variable Jacobian.
Hi, All
May I use microwave heating, error is
- Variable: mod1.mh.iomega
- Geometry: 1
- Boundary: 1 2 3 4 11 12 14 15 16 18
What can I can do?
What is the message meaning?
Thank you!
4 Replies Last Post 2011年12月21日 GMT+1 10:15
Posted: 1 decade ago 2011年12月20日 GMT+1 09:55
I have this problem too...
Posted: 1 decade ago 2011年12月20日 GMT+1 10:07
most probably you have an input error in one of the formula defining the frequency, or that you have given a formula that cannot be derived so that the Jacobian cannot be extracted, then the solver does not know how/where to "through" for the next guess in it's iterative solving process
Hi most probably you have an input error in one of the formula defining the frequency, or that you have given a formula that cannot be derived so that the Jacobian cannot be extracted, then the solver does not know how/where to "through" for the next guess in it's iterative solving process -- Good luck Ivar
Posted: 1 decade ago 2011年12月20日 GMT+1 18:38
Check whether u have entered all the values
Check whether u have selected domains for load or material
If u still get the same error, Check whether u have entered the correct equation or correct function definition
Hi Check whether u have entered all the values Check whether u have selected domains for load or material If u still get the same error, Check whether u have entered the correct equation or correct function definition Good luck
Posted: 1 decade ago 2011年12月21日 GMT+1 10:15
Thanks..
It was for wrong selected domain for equations.
Thanks.. It was for wrong selected domain for equations.
