Please help! (error: Undefined value found)
Hello everyone,
I’m working on the following model from Comsol library:
Batteries and fuel cells>>ht_pem.
When I change the geometry to a more complex one, for example using two or three connected channels instead of a single channel, it gives this error:
Undefined value found.
- Detail: Undefined value found in the equation residual vector.
There are 149 degrees of freedom giving NaN/Inf in the vector for the variable mod1.wH2 at coordinates:
(0.00195433,0.0194965,0), (0.00202966,0.0194855,9.01447e-005), (0.0020981,0.0193663,8.8374e-005), (0.00198618,0.0193565,0), (0.00201391,0.0194573,0.000187002), ...
As mentioned above, I use a model from comsol library, then this error cannot be because of BC’s or Initial variables. Changing the geometry cause this error!
Can anybody help me on this?
I appreciate any help.
5 Replies Last Post 2012年12月5日 GMT+1 01:36
Hello Saeid Movahed
Posted: 1 decade ago 2012年2月28日 GMT+1 09:43
Hi Saeid
i am having the similar problem. did you find answer for that.
Omer
Hi Saeid i am having the similar problem. did you find answer for that. Thanks Omer
Posted: 1 decade ago 2012年3月4日 GMT+1 15:50
Hi Omer
Sorry, I could not find the solution for the problem. Actually, I do not know what to do!!
Hi Omer Sorry, I could not find the solution for the problem. Actually, I do not know what to do!!
Posted: 1 decade ago 2012年3月6日 GMT+1 09:13
I'm having the same type of "new geometry"-related problem as you have. I have asked for help in the thread linked to below but so far no ideas on what is the problem.
www.comsol.se/community/forums/general/thread/26593/
I've tried clearing the old solutions but that did not change anything. When I did export the new geometry to a new COMSOL file it worked but it would of course be better to have everything in one file.
I'm having the same type of "new geometry"-related problem as you have. I have asked for help in the thread linked to below but so far no ideas on what is the problem. http://www.comsol.se/community/forums/general/thread/26593/ I've tried clearing the old solutions but that did not change anything. When I did export the new geometry to a new COMSOL file it worked but it would of course be better to have everything in one file.
Posted: 1 decade ago 2012年3月10日 GMT+1 23:05
It is strange, in my model, all the modeling proceses are the same as comsol library model(Batteries and fuel cells>>ht_PEM), and just geometry has been more complex,
I am confused and Ido not know what the problem is!
It is strange, in my model, all the modeling proceses are the same as comsol library model(Batteries and fuel cells>>ht_PEM), and just geometry has been more complex, I am confused and Ido not know what the problem is!
Posted: 1 decade ago 2012年12月5日 GMT+1 01:36
Guys I am in the same boat with you all. I just changed the geometry to a long channel with entrance at one of the end's and renamed the file, rest everything was left unchanged from COMSOL's example, I get the same error. Did anyone figure this out ? Could it be the number of iterations that have to changed. I doubt that is the problem as the solver quits almost instantaneously when asked to solve.
I was however able to use a little bit different geometry but I think it was about the same size of the example. It solved completely fine.
Any suggestions ?
Guys I am in the same boat with you all. I just changed the geometry to a long channel with entrance at one of the end's and renamed the file, rest everything was left unchanged from COMSOL's example, I get the same error. Did anyone figure this out ? Could it be the number of iterations that have to changed. I doubt that is the problem as the solver quits almost instantaneously when asked to solve. I was however able to use a little bit different geometry but I think it was about the same size of the example. It solved completely fine. Any suggestions ?
