FEM results
Good eveving to all
In my work i design CMUT cell,for model how to get FEM results after meshing the structure.any information about this pls reply.
1 Reply Last Post 2012年1月2日 GMT+1 10:12
Posted: 1 decade ago 2012年1月2日 GMT+1 10:12
you get your results via the plots you define and via the tables you populate via the Results Derived Variables (use a CNTRL Enter to see the list of the available variables (there are many ;). Or you define your own specific variables in a define variable node, but then you must rerun your solver, or at least perform an "update solution" (all govern by the right click, take care train your fingers, the "tennis elbow" syndrome might appear ;;)
Hi you get your results via the plots you define and via the tables you populate via the Results Derived Variables (use a CNTRL Enter to see the list of the available variables (there are many ;). Or you define your own specific variables in a define variable node, but then you must rerun your solver, or at least perform an "update solution" (all govern by the right click, take care train your fingers, the "tennis elbow" syndrome might appear ;;) -- Good luck Ivar
