Time integration inaccuracy
I implemented time integration of the convective diffusion flux, as I learned from this forum. It works as supposed, but it is rather inaccurate, mass balance deviates ca. 10%. Then I integrated the flux out of the system (surface integration of the total flux magnitude), exported the table in Excel where I made time integration manually. Now, the mass balance agrees with less than 1% accuracy. Hence, can I improve the time integration somehow in Comsol? It would save a lot of time.
2 Replies Last Post 2012年1月6日 GMT+1 09:28
Posted: 1 decade ago 2012年1月5日 GMT+1 16:16
are you talking about the new v4.2a "timeint(t1,t2,expr,tol,minlen)" (see the latest help) ?
I'm using it, but I haven't really tested it carefully, as currently I do not have an easy way to check. Another way would be to new dependent variable, as per KB explanations
Hi are you talking about the new v4.2a "timeint(t1,t2,expr,tol,minlen)" (see the latest help) ? I'm using it, but I haven't really tested it carefully, as currently I do not have an easy way to check. Another way would be to new dependent variable, as per KB explanations -- Good luck Ivar
Posted: 1 decade ago 2012年1月6日 GMT+1 09:28
No, I am not using 4.2a because my model built in 4.2 does not work in the new version. Mapped mesh causes an error message.
The method I use is to define an integration coupled variable and a global ODE, a note which I found here earlier.
No, I am not using 4.2a because my model built in 4.2 does not work in the new version. Mapped mesh causes an error message. The method I use is to define an integration coupled variable and a global ODE, a note which I found here earlier.
