Xueyuan,
I've been working on doing the same as you. I've been able to get this to work by following hints on this comsol forum - https://www.comsol.com/forum/thread/33446/parallel-computing-matlab-comsol. They start Comsol servers within a parfor loop, and then connect each individual parfor worker to a server with the "mphstart" function.
I hope this helps. If you need an example, please let me know.
Alex
Dear Alex
I am in exactly the same situation as Xueyuan. May I ask how are you solved the problem? In addition to the url that you mentioned, another url - //www.denkrieger.com/forum/thread/38557/parallel-computing-with-matlab-livelink-and-comsol?last=2013-07-20T17:37:08Z mentioned a similar solution. But for me, there are still mistakes. For example, when i used the code in the runfile,:
core=2;
pp=parpool(core);
comsolPort1 = 2036;
system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort1) ' &'] );
pause(1)
comsolPort2 = 2037;
system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort2) ' &'] );
pause(1)
and the next code in my function contains my Comsol model :
cd('D:\COMSOL\COMSOL55\Multiphysics\mli')
comsolPort=[2036 2037];
t = getCurrentTask()
labit=t.ID
mphstart(comsolPort(labit))
The calculation of the first round can be performed, but an error will be reported when the second round begins:
Error using mphstart
Already connected to a server
I thought the first-round model was still occupying ports, so I added the statement "Modelutil.disconnect;", but the calculation again prompted an error:
A connection to COMSOL could not be established. Please check that a COMSOL server is started prior to calling mphstart
I'm confused. Is there anything else to deal with ? Could you please kindly share your solution here? Looking forward to your reply very much, Thank you!
Kind regards,
Weikai Xu
>Xueyuan,
>Alex
Dear Alex
core=2;
pp=parpool(core);
comsolPort1 = 2036;
pause(1)
comsolPort2 = 2037;
pause(1)
labit=t.ID
Kind regards,
Weikai Xu
