Electrostatics vs. electric currents?
Hello, I am trying to simulate the electric field inside of a nanochannel filled the water using 2D geometry. The field results from three parallel electrodes (one with applied potential and another two with ground) embedded inside a glass substrate below the channel.
My first idea was to solve a poisson equation usingelectrostaticsin COMSOL. I checked that I get the correct result for a problem I can solve analytically - if the nanochannel was also filled with glass. Then I fill with channel with water and get a resultant electric field.
However, then I realized that water issignificantlymore conductive than glass, so maybe I should use current conservation equations (electric currents). This gives me a completely different magnitude and shape of electric field, though again for a simple problem of channel filled with glass the results are the same as what I get from electrostatics.
I realize the difference comes from boundary conditions at the water/glass interface, but I am not sure which way gives the correct result.
I attach my simulation file.
Thank you for any advice.
3 Replies Last Post 2020年3月5日 GMT+1 15:43
Posted: 5 years ago 2020年3月5日 GMT+1 12:03
Anna,
it is not the boundary between water and glass that causes the difference but the different electrical conductivity of the materials. I think the ec-approach is the correct one. Electrical conductivity must be taken into account because it is by orders of magnitude different in the two materials.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Anna, it is not the boundary between water and glass that causes the difference but the different electrical conductivity of the materials. I think the ec-approach is the correct one. Electrical conductivity must be taken into account because it is by orders of magnitude different in the two materials. Cheers Edgar
Posted: 5 years ago 2020年3月5日 GMT+1 15:23
Dear Edgar, Thank you, that makes sense! Does that mean that I choose between ES and EC approach depending on how much do to permettivities and conductivities vary between materials in the model? What if there is a situation if both vary similarly? Do you know if there is a way to account for both permettivities and conductivities? Best wishes, Anna
Posted: 5 years ago 2020年3月5日 GMT+1 15:43
EC takes both into account while ES ignores conductivity.
Edgar J. Kaiser
www.emphys.com
