2012年1月11日 GMT+1 07:40
I suspect that your solver settings are such that it skips the time varying input flux (but it could be something else.
First of all, with HT I strongly recommend that you use a V4 Waveform "pulse" function (or a Heaviside function in 3.5), to smooth the transition, such steps gives very serious problems to the solver. Then you need to have a fine mesh on the heat source side (I often add a boundary mesh along the constant Q flux boundary, for time dependent studies) and finally you must help the solver with better steps. By default its in "free" stepping mode (far down in the time solver setting nodes), use rather " Intermediate" and then in your time series define time steps, at least 3 per rise and fall times, then longer in between.
The default time stepper settings is for settling i.e. exponential type asymptotic decays, and not good for periodic BC changes
2012年1月11日 GMT+1 08:57
Hi Ivar,
Thank you for your reply and comments.
I tried a different way after I sent the message. I constructed a time varying heat flux input function with a combination of rectangle and analytic functions.
Rectangle Function (rect1):
Lower Limit: 8
Upper Limit: 16
Size of transition zone: 2
Analytic function (q_boundary_operation):
Expression: q_boundary*rect1(mod(time/3600,24))
argument: time
Then, I used q_boundary_operation(t) for the boundary heat source. This way, I could be able to apply the time varying heat flux. However, the results were not as I expected, and I suspected something was wrong about time stepping. At that moment, I saw your reply, and when I changed the stepping mode to "Intermediate", the problem was solved.
However, in your message, there is a point which is not very clear to me, that is; you mentioned: "in your time series define time steps, at least 3 per rise and fall times, then longer in between". Is this the times we define in the time-dependent solver (i.e. range(0,1[h],7[d])) or is it in another node?
Thanks again,
Tolga
Hi Ivar,
Lower Limit: 8
Upper Limit: 16
argument: time
Thanks again,
Tolga
2012年1月11日 GMT+1 09:32
you have also the "Definition - Functions - Waveform - Pulse" for repeated pulses
My comment was jsut that you should ensure that your time stepping you define with your "range" has a few time steps during the transition, to help the solver identify the steps, otherwise it might miss some
2012年1月11日 GMT+1 09:37
Thank you, Ivar.
Tolga
Thank you, Ivar.
Tolga
Thank you, Ivar.
Tolga
Thank you, Ivar.
Tolga
