Loss in heat instead of heat flux at boundary?
Is there a way to simulate a defined loss in heat at a boundary? So instead of having W/(m^2K) you'd have J/(m^2K).
Right now heat flux is the only time dependant variable that prevents my model from being stationary.
1 Reply Last Post 2020年3月8日 GMT+1 16:08
Posted: 5 years ago 2020年3月8日 GMT+1 16:08
Andreas,
wouldn't a stationary thermal model without any heat fluxes simply equilibrate to a uniform temperature in the whole model? If this is the case you could simply integrate the total heat capacity of the model and calculate the new temperature due to the heat loss and no need for a boundary condition.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Andreas, wouldn't a stationary thermal model without any heat fluxes simply equilibrate to a uniform temperature in the whole model? If this is the case you could simply integrate the total heat capacity of the model and calculate the new temperature due to the heat loss and no need for a boundary condition. Cheers Edgar
