Livelink for Matlab error
Sinéad Mannion Plasma Physics
Hi All,
How do you extract the results in Livelink with Matlab. I can use mphglobal on the tuning fork example but get an error when I try it on a plasma example
I get an error when I use
mphglobal(model,'plas.ne')
Any help with the commands would be greatly appreciated.
Kind regards
Sinéad
2 Replies Last Post 2020年4月16日 GMT+2 14:50
Posted: 6 years ago 2020年4月15日 GMT+2 21:14
Hi Sinéad,
What kind of error are you getting when using the above command? I am not familiar with the plasma module, but it seems that the dependent variable is plas.Ne, and not plas.ne. Since Comsol is case sensitive, this could possibly be the issue.
Cheers,
Alex
Hi Sinéad, What kind of error are you getting when using the above command? I am not familiar with the plasma module, but it seems that the dependent variable is plas.Ne, and not plas.ne. Since Comsol is case sensitive, this could possibly be the issue. Cheers, Alex
Posted: 6 years ago 2020年4月16日 GMT+2 14:50
Updated: 6 years ago 2020年4月16日 GMT+2 14:51
Thanks Alex, unfortunately it's not plas.Ne.
I've attached the error and the matlab code if you fancy a look!!! I just think I'm using the wrong Livelink with Matlab commands.
Sinéad
Thanks Alex, unfortunately it's not plas.Ne. I've attached the error and the matlab code if you fancy a look!!! I just think I'm using the wrong Livelink with Matlab commands. Thanks, Sinéad
