Reset History Error: The variable names must be unique
How do I go about finding the non-unique variable names???
1 Reply Last Post 2012年2月2日 GMT+1 07:44
Posted: 1 decade ago 2012年2月2日 GMT+1 07:44
if you have no other message its not obvious ;)
Most single letter variable names are already used by COMSOL and often you get no early warning, as COMSOL allows you to redefine a variable, but you must know what you are doing as else you get bizarre errors
Check your Parameters and Variable definitions, and try to use longer names
Hi if you have no other message its not obvious ;) Most single letter variable names are already used by COMSOL and often you get no early warning, as COMSOL allows you to redefine a variable, but you must know what you are doing as else you get bizarre errors Check your Parameters and Variable definitions, and try to use longer names -- Good luck Ivar
