Set point source programmatically
Hi everyone,
I'm experimenting with COMSOL's livelink to Matlab. In general, this is quite useful to programmatically set and run the models etc., but a few things I just cannot figure out. One of them: I would like to programmatically create a number of point sources (pressure acoustics module) given user-defined source amplitudes. However, I cannot assign the point source to the desired point in the geometry programmatically, because the identifier for the point changes.
Here is what I do (in Matlab)create a point in the geometry:model.component('comp1').geom('geom1').create('pt1', 'Point'); model.component('comp1').geom('geom1').feature('pt1').label('my_label'); model.component('comp1').geom('geom1').feature('pt1').setIndex('p', x_cord, 0); model.component('comp1').geom('geom1').feature('pt1').setIndex('p', y_cord, 0); model.component('comp1').geom('geom1').run('fin');
create a used defined function table:model.component('comp1').func.create(int2, 'Interpolation'); model.component('comp1').func(int2).set('funcname','my_func'); model.component('comp1').func(int2).label('my_func_label'); model.component('comp1').func(int2).set('argunit', 's'); model.component('comp1').func(int2).set('fununit', 'Pa');
create a point source:model.component('comp1').physics('actd').create(mls1, 'TransientMonopoleLineSource', 0); model.component('comp1').physics('actd').feature(mls1).set('Type', 'UserDefined'); model.component('comp1').physics('actd').feature(mls1).set('S', 'my_func(t)']); model.component('comp1').physics('actd').feature(mls1).label('my_ps_label'); model.component('comp1').physics('actd').feature(mls1).selection.set([6]);
The last line is the problem: I have to manually figure out which identifier (or however it's called) was assigned to point 'pt1' (which is '6' in my example). Is there a way of specifying the desired point using the name I gave it (i.e., 'pt1')? This would be much more robust and also intuitive, but I simply cannot figure out how to do this.
Thanks a lot,
Theo
Edit: Alternatively: Is there a way to programmatically ready out which identifier was assigned to 'pt1' after building the geometry, such that I retrieve '6' as an answer? That would be an unneccessary extra step imho, but an alternative solution.
2 Replies Last Post 2020年5月21日 GMT+2 07:02
Posted: 4 years ago 2020年5月20日 GMT+2 16:20
Hi Theodor
Sure there is. I wrote series of blog posts on this subjects a few years ago:
https://www.comsol.com/blogs/best-practice-working-model-m-files
The things you are asking about is in part 2. You should use the mphselectcoords function to get the entity numbers you're looking for.
Lars Gregersen
Comsol Denmark
Hi Theodor Sure there is. I wrote series of blog posts on this subjects a few years ago: https://www.comsol.com/blogs/best-practice-working-model-m-files The things you are asking about is in part 2. You should use the mphselectcoords function to get the entity numbers you're looking for.
Posted: 4 years ago 2020年5月21日 GMT+2 07:02
Hi Lars,
Great, that seems to work well - thanks a lot! I have a different question related to LiveLink with Matlab related to creating interpolation functions using a local table. Maybe you have an answer to this too, but it seems to make more sense to open a separate thread for that.
Thanks again,
Theo
Hi Lars, Great, that seems to work well - thanks a lot! I have a different question related to LiveLink with Matlab related to creating interpolation functions using a local table. Maybe you have an answer to this too, but it seems to make more sense to open a separate thread for that. Thanks again, Theo
