Magnus Ringh
COMSOL Employee
4 years ago
2020年7月8日 GMT+2 09:06
Hi Ben,
There are large differences between versions 5.2 and 5.5. COMSOL Multiphysics is backward compatible, so that you can open and run 5.2 model files in version 5.5, but the other way around is more problematic. The 5.5 code might contain functionality that does not exist in version 5.2, and there may be other changes that affect the compatibility. I strongly recommend upgrading to version 5.5, which contains a lot of new and powerful functionality.
That said, you are correct:model.component()corresponds tomodel.modelNode()in earlier versions of COMSOL Multiphysics.
Magnus Ringh, COMSOL
Hi Ben, There are large differences between versions 5.2 and 5.5. COMSOL Multiphysics is backward compatible, so that you can open and run 5.2 model files in version 5.5, but the other way around is more problematic. The 5.5 code might contain functionality that does not exist in version 5.2, and there may be other changes that affect the compatibility. I strongly recommend upgrading to version 5.5, which contains a lot of new and powerful functionality. That said, you are correct: `model.component()` corresponds to `model.modelNode()` in earlier versions of COMSOL Multiphysics. Best regards, Magnus Ringh, COMSOL
4 years ago
2020年7月8日 GMT+2 20:33
Thank you, Magnus
