Peeling Test
Hello all,
I want to compare my experimental data with the simulation in COMSOL, so I used the Cohesive model as reference. However, it produces error and fails to find a solution.
Overall Setup: * 3D Model
  • 2 layers(first layer Mo and second layer SS)
  • Solid model: Isotropic
  • Initial crack 30[mm]
  • Total length 100[mm]
  • Force applied at the edge from the top layer.Study>Step1: Stationary> Parameter( Force[range(0,1,300)] )
  • Fixed constrain (lower layer)
  • N_strength,S_strength(8%N_strength) , GIc and GIIc (8%GIc )from the experiment.
Desired Results
  • Plot Froce-Displacement
I have constrained the lower layer, so I just apply a force and i was expecting to get the maximum force and displacement when the peeling start.
    • Feature: Stationary Solver 1 (sol1/s1)
  • Failed to find a solution for all parameters, even when using the minimum parameter step.
  • Undefined value found.
  • Undefined value found in the equation residual vector.
  • Returned solution is not converged.
  • Not all parameter steps returned.
Do you have any ideas about improving the model?
Thank you for your help.
Roger Ona
0 Replies Last Post 2020年7月8日 GMT+2 23:27
Hello Roger Ona
