2012年3月1日 GMT+1 16:43
for me they mesh OK (4.2a .166) in physics controlled mesh, in Normal you get a warning, that dissapears from "fine". Ok its not a very nice mesh but with all the silver edges you souldnt expect much better.
You can also make a structured mesh
add a triangular mesh node (2D) and select boundaries 4 6 16 21 (by the way it's 4 and 21 that are the silver edge parts) THen add aa sweep mesh for all domains, add a Distribution sub node and duplicate 2 times, select only domain 3, set 3 layers, select domain 2 and use the default 5 layes, and the last distribution for domain 1 also with 5 layers.
I suppose 3 is a magnet, if so its nice to have the fillets, it reduces the singularities of the field at sharp corners and vertexes. But perhaps you should also fillet the lower iron to get rid of the small faces 4 and 21, I do not think it will change a lot your final simulation but it will improve the mesh quality. Its not that easy on the opposite side, andI'm not sure you can do much either
But for me it meshes, or have I missed something ?
2012年3月1日 GMT+1 18:37
Thanks Ivar for your fast reply.
I was trying to mesh it mapping the surface and sweping the entire body (it works perfectly with less complex geometries).
Anyway, due to my lack of experience meshing on Comsol, I will follow your advice and keep on with your improved mesh.
All the best,
F. Xavier Borras
All the best,
F. Xavier Borras
