Robert Koslover
Certified Consultant
5 years ago
2020年9月5日 GMT+2 18:18
In regard to definitions, see http://www.antenna-theory.com/definitions/axial.php or https://en.wikipedia.org/wiki/Elliptical_polarization .
In regard to checking the handedness of circular polarization, or for a quick/qualitative view of the orientation and ellipticity of the polarization, I usually just plot an animation using Comsol's arrow-plot on a surface capability, and watch the E vector sweep around as the wave phase varies. You can do this with the fields in/on your model volume, or you can even do it for far-field plots on finite surfaces. For example, you can do an arrow plot of Efarx, Efary, and Efarz on a hemispherical surface around the origin.
In regard to checking the handedness of circular polarization, or for a quick/qualitative view of the orientation and ellipticity of the polarization, I usually just plot an animation using Comsol's arrow-plot on a surface capability, and watch the E vector sweep around as the wave phase varies. You can do this with the fields in/on your model volume, or you can even do it for *far-field* plots on finite surfaces. For example, you can do an arrow plot of Efarx, Efary, and Efarz on a hemispherical surface around the origin.
